ATARI ST SMSQ/E
genetika
ATARI ST SMSQ/E
Post by genetika »
Hi.
Where I can download SMSQ/E for ATARI ST ? :-)
Is it still available ?
Thanks!
Massimino
Re: ATARI ST SMSQ/E
genetika wrote:Hi.
Thanks!
Massimino
I *think* it's in the Binaries download from Wolfgang's site at http://www.wlenerz.com/smsqe/
IIRC, it's called SMSQE.PRG and is for native Ataris (not the ST-QL emulators) - hopefully someone will correct me if I'm wrong (not at home to check my facts).
Re: ATARI ST SMSQ/E
Exactly.
The .prg is a native ST application for the Atari ST with no QL hardware emulator (although I think - it's been some time I had a look at it - it takes notice of an ST/E VME-Bus emulator, which is, however, pretty unlikely for anyone to have). Note the non-hardware emulation will only work in b/w mode (640x400). The color modes the ST can produce have less than the 256 pixel height which is the minimum for SMSQ/E.
stephen_usher
Re: ATARI ST SMSQ/E
Post by stephen_usher »
Does it run on an Atari TT030 or Falcon030 though? They have a 640x480 colour mode.
Would be interesting to find out. I may try downloading and seeing if it'll run tonight actually, as I have my TT set up at the moment.
stephen_usher
Re: ATARI ST SMSQ/E
I've just tested it. It does run... in monochrome... as a set of windows cowering in the top-left of the screen. Not that useful.
Oh well.
genetika
Re: ATARI ST SMSQ/E
Post by genetika »
it works !
SMSQ/E 3.31 - Atari STE - 32Mhz - 4MB - Monochrome
/HATARI Emulator 2.0/
genetika
Re: ATARI ST SMSQ/E
Post by genetika »
Hi.
How I can execute SMSQ/E programs on ATARTI ST?
I tried to run some applications but I receive the following error: "bad parameter"...
Do I need to recompile the apps under the ATARI ?
Thanks in advance.
Kind regards,.
M.
Re: ATARI ST SMSQ/E
This sounds like the classical problem of having lost the QDOS file header when transferring the program onto the ST. Note DOS or TOS-formatted disks cannot store a QDOS file header. How did you get the program to the ST?
tcat
Re: ATARI ST SMSQ/E
Post by tcat »
Being owner of ATARI ST, I am curious to give it also a try. I read somewhere, cannot now remember the source, that SMSQ/E was originally designed for ATARI ST, as initially QL did not have enough computing resources, only later when Gold/Trump cards came around with more memory and CPU, was possible to port SMSQ/E to QL.
Tom
daniel_baum
Re: ATARI ST SMSQ/E
Post by daniel_baum »
I tried getting this to work in Steem, with no success
One day I will retrieve my ST from the attic and see if it still works.
D.
