Removing Jobs From QLE
Hi can any one help me How do you Remove Jobs from QLE so it is only QDT like it was when it first came out I want to keep the jobs what help QDT to work like QMenu and the other bits that make it work OK thanks Simon Foster
Re: Removing Jobs From QLE
Hi Simon,
Without disecting the QLE boot process, try pressing ESC on the iniitial boot screen and enter qle_cfg and you can configure QLE that way.
If you find QLE too hard to configure, try Black Phoenix maybe more suitable.
But I think most of the fun in this sort of thing is configuring the way the system boots up
On qle_cfg what settings do I put it on to have all the Apps and games but just QDT not QLE OK thanks Simon Foster
- QLvsJAGUAR
- Gold Card
Yes, the easy way is to use the QLECFG program. See seperate thread. With the use of QLECFG you can get a pretty clean QDT Installation running on QL/E. See attached screenshot. All that in seconds, and without having to change a single line of program code.
QL forever!
Urs
P.S. I'm thinking of adding ScrapStuff to the QPAC2 family or having a new config item called "Clipboard stuff"
QL forever!
Urs
QL forever!
Hi Urs,
Can a graphical QLE_CFG version be written, it was make the configuration easy for someone that is a beginner or not that good at written boot programmes.
I use SMSQmulator JVASGET & JVASPUT commands to get/insert the Operating System Clipboard to Scrap. It only allows samll amounts of data to be inserted into SCRAP due the limitiations on the SCRAP thing. But a nice feature
