Jurgen Falkenberg Scanner
Does anyone have the software which goes with the Jurgen Falkenberg scanner interface - see
http://rwapadventures.com/ql_wiki/index ... er&lang=en
Re: Jurgen Falkenberg Scanner
I now have a copy of this software if anyone needs it - I will pass it onto Dilwyn, as it is not much use without the hardware :)
RWAP wrote:I now have a copy of this software if anyone needs it - I will pass it onto Dilwyn, as it is not much use without the hardware :)
As luck would have it, I now have a manual, which needs scanning, so I can add them both.
I also happened across manuals for Q+5 and Qontrol-II cards which are about to go on the Replacement Manuals page too.
Excellent - some more stuff to add to the Wiki....
What did the output look like from the scanner? :)
