Software Question
Mr_Navigator
QL Fanatic
Software Question
Post by Mr_Navigator »
I think I have asked this before but cannot find the thread.
In SuperBASIC, can you code it so that some text/command is in #0 as if it has been typed in in #0, and if that is possible, can the Return/Enter command be done the same way?
Re: Software Question
I think you are looking for something like the Turbo Toolkit command - COMMAND_LINE (?)
There is also a TYPE_IN procedure - I think that is from DIY Toolkit...
Both COMMAND_LINE and TYPE_IN are from Turbo Toolkit.
- COMMAND_LINE picks SuperBASIC #0 into the foreground to receive input (Much like HOT_PICK)
- TYPE_IN x$ behaves as if x$ would have been typed from the keyboard into the current keyboard queue
If you want TYPE_IN to also add a LF at the end, just add it to x$ like
TYPE_IN x$&CHR$(10)
tofro wrote:Both COMMAND_LINE and TYPE_IN are from Turbo Toolkit.
TYPE_IN x$&CHR$(10)
Thank you for the clarification - I wonder what the command is in DIY Toolkit.....
Mr_Navigator
QL Fanatic
Thanks guys, I now have a couple of very small routines that help greatly in editing and programming SuperBASIC. :P
Mr_Navigator
QL Fanatic
Moving on from the original question I now have another. (VP its a shame there isn't a Coding only section on the forum :idea: )
Anyhoo, I have TK2 and Turbo Toolkit installed as standard on the BBQL
I wish to save an area of the screen, print draw something to it and then restore the original screen back. Now I think know I can do this for the whole screen but that uses 32K of memory. Also I might adapt this to maybe do successive or recursive 'windows', 32K a pop is rather extravagant. More like a notification message I suppose.
I know there are other extensions out there, but I dont want to add any further ones to those i already have. Is this possible?
In pseudo code is would think it would be something like:
 Def Proc Message (Text$, x, y)
  TSize = LEN (Text$)*6
  ScreenSave x, y, Tsize
  CURSOR x, y: PRINT Text$
  PAUSE 250
  ScreenRecall x, y
 End Def
or
  ScreenSave x, y, xmax, ymax
  CURSOR x, y: PRINT Text$ etc.
  PAUSE 250
  ScreenRecall x, y
 End Def
If you are using Minerva, you can use the extended MODE command to switch between the First and Second screen.
You could write on Screen 1 then change to Second 2 or vice versa.
The syntax for the extended MODE command is in the Manual, it has been nearly 15 years since I thought of this.
I did write some extensions to use the second screen, but I can not find them at present.
Mr_Navigator wrote:I know there are other extensions out there, but I dont want to add any further ones to those i already have. Is this possible?
Lee,
if you have Turbo TK already, have a look at MOVE_MEMORY and the examples in the manual and on file - It describes some cases for saving parts of the screen..
You could assume the screen to start at $20000, but probably shouldn't if you want to be compatible with higher res screens and/or Minerva. You could also assume the length of one scan line to be 128 bytes (and probably shouldn't, for the same reason). But finding out would need something like display_cde - That's not part of Turbo TK.
Lee,
Moderately tricky one this, if wishing to avoid use of external extensions.
Firstly, screen address. A degree of assumption can be made for QDOS, and then use SBASIC extensions SCR_BASE and SCR_LLEN for SMSQ/E perhaps. Something like:
screen_address = 131072:line_length=128 : REMark QDOS defaults
IF VER$ = 'HBA' THEN screen_address=SCR_BASE:line_length=SCR_LLEN
There are a couple of IF...BUTS... here, though:
1. Does not cater for Minerva second screen, or for uQLx's selection of extended screen sizes.
2. I am not sure it would compile on Turbo (not saying it wouldn't, I just don't know), I know older versions of Turbo might choke when the compiled job is run on a system not having compiled extensions installed.
Next, we come to the issue of the number of bytes per pixel. It is 2 bytes per group of 8 pixels in mode 4, one byte per pixel in mode 16 (Aurora/QPC2 256 colour mode) and two bytes per pixel in modes 32 and 33 (QPC2, QXL, Q40, Q60). This would need DISP_xxx extensions to return the mode and allow you to work out where along the lines the area starts. It's actually easier in high colour modes because mode 4 means you'd have to make sure you work in multiples of 8 pixels which are all word aligned. It can get very fiddly.
Certainly, Display_Cde (which can be linked to Turbo or QLib programs and supplied with other software free or commercial) can give you the information to build your own routines based on the above information. There is a demo routine with it which stores the whole screen, but not partial windows, maybe that's make an interesting little extra demo if I get time to write one if ever I get on top of current projects!
Personally, I use Easyptr 4 and QLiberator for this kind of thing, where commands like WSAIN, WSARS etc allow you to save and restore window areas with ease. Haven't used the TurboPTR package enough to know if there's and equivalent in there for use with Turbo, although George did do some work on Turbo a year or two ago to try to ensure it could compile Easyptr stuff.
There's also software on Quanta library disk GR01 called VIRTUAL_SCREENS by Ron Dwight which may be useful. And on GR02 there's WINDOWS. I have no idea if either of these works on extended screens. Just browse the library guide searching for WINDOWS to find them.
Something along the lines of this would probably work, I guess (untested, will also only work for screen areas that are byte-aligned )
100 deffn ScrSave (x, y, w, h)
110   local llen, scrBase, bpp, pixlen, blen, address, bstart, mneed, srcPtr, dstPtr, i
120   scrBase = 131072 : llen = 128 : bpp = (128 * 8 / 512) / 8 : rem Bytes per pixel for mode 4
130   if ver$ = "HBA" then
140     scrBase = SCR_BASE
150     llen = SCR_LLEN
160     bpp = (llen * 8 / SCR_XLIM #0) / 8
170   endif
190   blen = int ((w + 7) / 8) : rem length of one window scanline in bytes, rounded up
200   bstart = scrBase + (y * llen) + (x * bpp) : rem start address
210   mneed = blen * y + 4 : Rem memory needed, +2 words for width and height
220   address = ALLOCATION(mneed)
230   poke_w (address, w) : poke_w (address + 2, h) : Rem remember width and height
240   dstPtr = address + 4 : srcPtr = bstart
250   for i = 1 to h
260     move_memory srcPtr to dstPtr, blen
270     srcPtr = srcPtr + llen : dstPtr = dstPtr + blen
280   endfor i
290   ret address
300 enddef
ScrPut would work simply the other way round ;)
Note the width and height of the save area needs to be saved as well in order to get the screen area right when restoring an image.
