Assembler Programming Problem
I was wondering if anyone can give me any advise on the following m/c problem, because I'm obviously missing something, please?
I've created an SBASIC extension called i2c_say
I want to be able to call it in 3 ways
i2c_say("<some text>")
i2c_say(<integer>)
i2c_say(<integer>,<integer>)
When it's called I check if the first parameter is a string, this seems to work, and if it's not a string it then checks for the first parameter being a number again this seems to work (or at least it's accepted)
But when I try the last version, i2c_say(<integer>,<integer>), when I press enter I just get "bad line" at the command line
I didn't think that sbasic would be checking the number of parameters, but I guess I'm wrong please?
Any thoughts please?
Tony
i2c_say(<integer>)
Tony
Re: Assembler Programming Problem
It seems it does like i2c_say 1,1 (i.e. no brackets)
Is it really as simple as that please?
Thanks
Tony
Thanks
Tony
It can be that simple. I used a BASIC once that required a space between every element.
You don't use the parentheses when calling a procedure or function. Only when creating it. I imagine that carries across.
Thanks DaveDave wrote: Tue Sep 16, 2025 6:51 pm It can be that simple. I used a BASIC once that required a space between every element.
It's a strange one though because the Minerva I2c_io() uses brackets fine and that has a variable 2 to 4 parameters
Maybe it's because that's a function rather than a procedure
Tony
It’s occurred to me that the extension might be better off as a function anyway so it can return just a status rather than an SBASIC error, in most cases
- NormanDunbar
- Forum Moderator
Hi Tony,
If you change your procedure to a function, you'll need to be very very careful about keeping the maths stack tidy. Procedures let you run riot and tidy up for you, functions mean you have control!
If you are reading my Assembly Language book, ignore anything that says what the value of A1 is in entry. That applies to the BBQL only. (I might have updated it to correct for SMSQ, I know I've done the experiments and documented it on the forum, somewhere!)
This is exactly the solution. Functions need parentheses, procedures don't and throw a "Bad Line" error if you use them.t0nyt wrote:Maybe it's because that's a function rather than a procedure
Thanks NormNormanDunbar wrote: Wed Sep 17, 2025 7:05 am Hi Tony,
I'll leave it as a Procedure for now then and see if that presents any issues in normal use once I've got it all running
I have about 12 functions in the extension but these don't take parameters so was able to copy the code for the return of a value from your book
Tony
If memory serves. Functions in QDOS need parentheses, but in SMSQ/E does not.
It seems if you try and read a string parameter before then trying to read numeric value(s) the first number gets read as a string
So my plan to have
i2c_say("<text>")
i2c_say 16
i2c_say 16,1
Won't work
Will have to split them into 2 procedures I guess
So my plan to have
i2c_say("<text>")
i2c_say 16
i2c_say 16,1
Won't work
- NormanDunbar
- Forum Moderator
Really? I'm surprised!t0nyt wrote: Wed Sep 17, 2025 5:46 pm It seems if you try and read a string parameter before then trying to read numeric value(s) the first number gets read as a string
You might find section 7.5.2, table 7.7 and section 7.6 in the 2020 edition of my book useful. You can determine each parameter type from 1(a6,a3.l) - bits 0--3 determine the type of each parameter. You should be able to fetch them one by one if necessary.
I've never written a procedure which can take different parameter types on different calls, so I might be wrong. Worth an experiment maybe?
HTH
