My Sandy QXT640 has a really messy and damaged front plate. It's a flat piece of aluminium 46x9cm with 2 holes for drives and a couple of smaller holes for LEDs. It's painted black and has white text and stripes.
I'd like to re-create a new one. I heard that jlcpcb are also able to provide CNC aluminium parts. I have no idea about 3D modelling, anyone able to offer some advice? How would I apply the text and stripes... get decals made?
QXT640 front, anyone good with 3D design?
Re: QXT640 front, anyone good with 3D design?
You don't need decals. You can create a image in Corel Draw, Inkscape, Photoshop or any other image processor, then print it on a cutter plotter on a vinyl stickerChr$ wrote: Sat Jul 05, 2025 6:20 pm I'd like to re-create a new one. I heard that jlcpcb are also able to provide CNC aluminium parts. I have no idea about 3D modelling, anyone able to offer some advice? How would I apply the text and stripes... get decals made?
Paint the face plate white. Then stick the printed image on the face plate and peel everything except the lines and the text.
Print the faceplate black. Then peel the vinyl sticker to reveal the white lines and white text.
- Derek_Stewart
Just make CAD file and export it as : STEP,STP,DWG,DXF, they also accept PDF, ZIP and RAR files
Replacing the front plate with a black PCB might be another approach.
Once you have the design, you could also have a PCB (no copper traces at all) manufactured by one of them Chinese factories for little money, they make them in black with white print. Should make a perfect replacement.
There might be an easier way: You could paint the entire front panel white or silver and then use a "front panel program" to design and print a self-adhesive film with a laser printer and then wet-apply it.
Program (in German): https://www.schaeffer-ag.de/frontplatten-designer#
Self-adhesive film:
Self-adhesive film:
Thanks for the suggestions. I will investigate the methods.
We originally screen printed these over black hi-tack paint. A few of them got a layer of clear coat at the time - I think two or three as Julia wanted one that was glossy. I thought it was a bit tacky using a Commodore-associated font.
Anyhow, yes, if you design it as a PCB, then order 5 and clear coat them with flat lacquer when they arrive, you could send the other 4 off to other QXT users. If you splash out and order 10 it would be for the price of 7. You'd then be able to meet the entire world demand for QXT front plates.
