Digital C
Introduce yourself here!
jan Etan
Digital C
Post by jan Etan »
I like to discuss anything related to Digital C SE with people who use it (or not).
I am looking for a version of HiSoft Assembler and its documentation.
Do you know if there is something similar to FujiNet for QL ?
jan Etan
swensont
Re: Digital C
Post by swensont »
Back in the day, I was big into Small-C because C68 was hard to get a hold of (at least in the US for non-Quanta folks). I published some Small-C code in the "QL Hacker's Journal". I also wrote the "Small-C Companion" which provided more detail on using Small-C and creating a small library with new functions. I also reformatted the Small-C document to look better. I did the same with the Digital C document. They all be be found at the following links:
http://swensont.epizy.com/SmallC.pdf
http://swensont.epizy.com/SmallC_Compan.pdf
http://swensont.epizy.com/DPC.pdf
http://swensont.epizy.com/qhjall.zip
I also wrote a Digital C front end. That is in SMSQzine #4:
http://swensont.epizy.com/smsqzine04.pdf
http://swensont.epizy.com/smsqzine04.zip
This all might be useful to you.
Tim Swenson
jan Etan
Re: Digital C
Post by jan Etan »
I already have the pdf files (very good starting point). I will read your mag and the qlhj. Thanks :-)
