Modifying modern floppy drive for QL
Factor6
Post by Factor6 »
I have a GoldCard with floppy controller. When I tried to connect a standard PC 3,5" floppy drive, it didn't work. Is it possible to modify such a FDD somehow to get it working on the QL? For example the way like on Amiga (some little soldering..) And will the HXC floppy emulator work with GoldCard?
thanks,
F6
Re: Modifying modern floppy drive for QL
You can get a modern PC disk drive to work with the QL by taking a standard PC floppy disk drive cable and removing the existing twist in the cable. You then need to swap pins 10 and 12 on the cable to get the floppy disk recognised as the master (DS0)
If you are really lucky, there are some jumpers on the disk drive to select DS0 or DS1 (normally not on a modern disk drive though) in which case you can move the jumper to DS0 and just use a straight untwisted cable.
As for the HxC Floppy disk emulator - this works well with the Gold Card to allow DD and HD disk image access. Unfortunately, I still need an ED disk image to try!
Factor6
Post by Factor6 »
It works! Thank you!
F6
Mr_Navigator
QL Fanatic
Post by Mr_Navigator »
RWAP wrote:You can get a modern PC disk drive to work with the QL by taking a standard PC floppy disk drive cable and removing the existing twist in the cable. You then need to swap pins 10 and 12 on the cable to get the floppy disk recognised as the master (DS0)
So will this work for two FDs ?
Of course, the second floppy disk drive just needs to be placed on the cable before the twist on pins 10+12 (as PC floppy disk drives are set up as DS1 (FLP2_) by default).
belg4rion67
Post by belg4rion67 »
Hi, I've followed your suggests and my floppy drive works very fine with QL and Sandy drive interface!!
Someone knows if is possible to connect and use a DD/HD (1.44 Mb.) floppy disk drive?
Many thanks for your help
Only original hardware! :)
A HD (1.44Mb) drive will work in the same way subject to the above modifications.
However, only the Gold Card and Super Gold Card by Miracle Systems can read/write HD disks.
All of the other disk interfaces will try to format HD disks to DD (720K) which can be very unreliable.
belg4rion67
Ah ok Rich, I suppose that but I thought there was a firmware version that could do it...
I'm satisfied yet in this manner: more better than microdrive :D
ergonql
Post by ergonql »
Hi All,
as I have an original QL DD floppy disk drive (i.e. case, power supply etc.), what I should do if I just would like to swap the existing DD floppy drive with a new HD one to upgrade my unit?
thanks and regards
Davide
Hi Davide,
The HD drive maybe designed for a PC, so the drive select will be set to DS1 which the QL will see as FLP2_
You need to change disk drive select to DS0 for FLP1_
