HD and Directories
genetika
HD and Directories
Post by genetika »
Hi.
I connected a QUBIDE card on my standard QL (with SuperGoldCard, Minerva ROM and SuperHermes card). I connected a 2GB CF CARD to the QUBIDE interface using a CF to IDE adapter. All is functioning well ... I formatted the 1 partition (128M)...
Now.. I would like to boot SMSQ/E Gold from the HD.
I copied the SMSQ/E files on the HD and I created the following BOOT file:
TK2_EXT
LRESPR WIN1_SMSQ_GOLD
The problem is that now I have a SMSQ/E Gold boot looping ... :(
How is possible to create sub-directories on the HD and using them to boot different applications?
Ex.
MAKE_DIR WIN1_SMSQ_
WCOPY FLP1_ TO WIN1_SMQ_ (flp1 contains SMSQ/E Gold files..)...
Is it correct ?!
Thanks in advance for your help!
Kind regards,
Massimino
:D :D :D :D
Re: HD and Directories
genetika wrote:Now.. I would like to boot SMSQ/E Gold from the HD.
TK2_EXT
Method 1: create a manual boot, e.g. press F1 to load SMSQ/E, press F2 for QDOS, press F3 to run main BOOT program
Method 2: test to see if SBASIC already there:
100 v$ = VER$
110 IF NOT(v$='HBA') THEN LRESPR win1_smsq_gold
120 : REM rest of your boot program
I put the VER$ into a string variable because some versions of QDOS don't cope well with putting VER$ in an IF...THEN statement for some reason.
Ex.
MAKE_DIR WIN1_SMSQ_
Is it correct ?!
Yes, apart from a small typo in your example ...WCOPY FLP1_ TO WIN1_SMSQ_
TK2_EXT
100 v$ = VER$
This is the method I have used for years, although actually SMSQ_GOLD should (!) recognise that it is already loaded and try not to reinstall if you use LRESPR.
Maybe this has been broken...
