GOTEK SFRC922D
GOTEK SFRC922D
I try to connect my GOTEK SFRC922D but my laptop does not recognize it . The message is DFU in FS Mode
I need the Gotek in order to replace my 720k floppy but I cannot step further. Any help?
Re: GOTEK SFRC922D
Sound like your Gotek is in Device Firmware Update mode.
If you look on the Flash Floppy WIKI, there is information on your Gotek version
https://github.com/keirf/flashfloppy/wiki/Gotek-Models
Re: GOTEK SFRC922D
I try to flashfloppy my gotek but the procedure ends with message Critical" Error no Gotek found". The windows 10 report as AT32 BOOTLOADER DFU. The Gotek model is SFRC922D. Any suggestion?
Re: GOTEK SFRC922D
What process ard you programming the Gotek?
There is much information on the WIKI, maybe try asking the designer of the Flash Floppy system.
I have two Goteks to programme, so I will get this done and report back.
Last edited by Derek_Stewart on Sun Nov 19, 2023 10:20 pm, edited 1 time in total.
Re: GOTEK SFRC922D
Hi Derek an Mhatias.
Sorry Mhanias if I get into this discussion. I have a Gotek SFRC922AT3 that I have never managed to make it work with the ql. According to Flashfloppy, this model lacks of usual header pins . In the figure to which the link refers, there is a pin boot 0. Must it be connected? If yes how?. Could this be the problem?. How do you configure the other pins? .
Thanks for your help.
Marco
Marco
Re: GOTEK SFRC922D
Thank you all for your support.
1. My PC with windows 10 and another with windows 7 never recognized the gotek . I tried everything.
2. But when insert a usb stick with proper files (Empty DD DISK_img.hfe, qlchaos.img, IMAGE_A.CFG) the gold card recognised it! as flp2_
3. The jumper setting is at S1 and J5-JA
I can send you the files if you want
Best wishes
Michael
Best wishes
Michael
Re: GOTEK SFRC922D
This would be very nice. I have to repair a ql with Gold Card and I hope to be able to use my Gotek instead of a floppy drive.
Best regards
Marco
Best regards
Marco
Re: GOTEK SFRC922D
Have you seen this QL Forum thread:
https://www.theqlforum.com/viewtopic.php?t=3020
Also see this link in the HxC Floppy Drive Emulator forum:
https://torlus.com/floppy/forum/viewtop ... 87a41e3c64
