How to use on Mister floppy games via qxl.win
- ROM Dongle
Hi all! I'm using Sinclair QL via Mister Core.
I've bought some games from RWAP Software. They are in floppy / folder format and I would use them on Mister (that doesn't support floppy).
Most of them don't fit the *.mdv size so I was wondering if I can use qlx.win, but how can write in it? My (registered) copy of Q-Emulator, for example, can not write but only read...
Thanks in advance!
Thanks in advance!
Re: How to use on Mister floppy games via qxl.win
Can you not use FLP imagess, which allow image of floppy disk images of 360K(SS), 720K(DD), 1440K(HD).
Since you have registered copy of Q-emulator, just left click on one of the empty drive slots and selection Floppy Image to create a new Floppy image fle
Attch MDV image file and FLP image file to empty drive slot then copy the contents of the MDV file to the FLP image file, transfer to Mister and play the game...
- ROM Dongle
Alas Derek, problem is that floppy image contents size exceeds MDV maximum size, so I was wondering if I can use qxl.win...Derek_Stewart wrote:Hi,
You can read/write/format QXL.win images using QPC2.
You can also use Wolfgang Lenerz's QXLWinReader Java application to transfer files from Windows/MacOs/Linux space into QXL.win images.
Place the QXL.win image as "boot.vhd" in the QL folder of your Mister SD (or as QXL.WIN onto a card in the secondary SD slot as win2_)
- mk79
Not sure where you got that from, of course QemuLator has write access to QXL.WIN style files. You can also use QPC2 if you want, but both should work for transferring stuff from floppy image to .WIN image.AmintaSinclair wrote:Most of them don't fit the *.mdv size so I was wondering if I can use qlx.win, but how can write in it? My (registered) copy of Q-Emulator, for example, can not write but only read...
Sorry, I misread your message, just what has been said abd create a QWA container and copy the flp image file contents to the QWA container file AKA QXL.WIN file.AmintaSinclair wrote:Alas Derek, problem is that floppy image contents size exceeds MDV maximum size, so I was wondering if I can use qxl.win...Derek_Stewart wrote:Hi,
Or copy the images into the a QWA file and use FDI to mount the image file in the Mister system.
I had the same problem with the Q68, which can not mount MDV or FLP images, so using MDI for MDV and FDI for FLP images solves the problem.
The image files can be stored in a QWA container file accessed as a WIN drive of in a FAT partion on the Q68 SD Card.
I would this Mister does the same thing.
- ROM Dongle
Thanks you all for the useful suggestions!
I've managed to put the games file on "hard disk" (*.WIN file) but now how am I supposed to run a game?
Please take a look at my directory: what file - for each game - I have to launch, and using what command?
- NormanDunbar
- Forum Moderator
Assuming this is "win1_", and assuming you have a backup, or can easily reproduce things, then taking farmer as an example:
Have fun and good luck.
- Execute the command load "win1_farmer_boot" to load the boot file into memory.
- You now need to edit the code, looking for places where a device name is used. Sometimes the author will have set a variable to the default device.
- If the author has done so, just change the device name in quotes to "win1_". Then save the file using save_o "win1_farmer_boot" as your command.
- If not, then the author was lazy (!) and you need to change all, for example, "MDV1_" to "WIN1_". It could be "FLP1_" of course. Then save the file using save_o "win1_farmer_boot" as your command.
- ROM Dongle
Thanks Norm, I think in my case is "FLP1_", so I have to change it, but where? There is a native editor in Sinclair QDOS, in the version supported by Q-emulator?NormanDunbar wrote:Assuming this is "win1_", and assuming you have a backup, or can easily reproduce things, then taking farmer as an example:
[*] If not, then the author was lazy (!) and you need to change all, for example, "MDV1_" to "WIN1_". It could be "FLP1_" of course. Then save the file using save_o "win1_farmer_boot" as your command.[/list]
Moreover, where I can find a first tutorial about all those commands?
Davide
Does WIN_USE FLP command work ?
If it does then it means any reference to FLP automatically looks at WIN.
Use WIN_USE without any name to reset things.
You should then be able to run each game by running its Basic boot file:
LRUN flp1_cuthbert_boot
etc
All references to FLP within the boot file (or elsewhere) will be pointed to files on WIN device.
etc
David
