Digital Lander
stevepoole
Digital Lander
Post by stevepoole »
Covid has had me revising and improving programs written some time ago, to work now on most platforms.
Just unzip and LRUN Digital Lander, answer Yes/No, difficulty ( low number is hardest ), and use left/right keys or ESCape.
The idea is to guide numbers as they fall down onto the same number (on the bottom line), when you score a hit.
When the whole grid has been filled, you get your result as the percentage of hits/tries.
Not as easy as it would first appear...
I will do this one in JavaScript when I find out how to acces tactile-screen inputs.
Steve.
Lander2_bas.zip
(1.49 KiB) Downloaded 110 times
Cristian
Re: Digital Lander
Post by Cristian »
Thanks!
Re: Digital Lander
Thnak you Steve!
stevepoole
Re: Digital Lander
Hi Folks,
I was hoping to convert the lander program for smartphones, which would require accessing the tactile controls.
But the JavaScript routines to do this are not at all straightforward to use !
Perhaps a normal keyboard version for PCs will be possible ? I will have a go at it...
Steve.
