LibVT
SM7I
LibVT
Post by SM7I »
Hi !
Anyone got any luck with libvt on xtc68 ? I get Undefined Symbol: '___ANSICONF__' when trying to compile using -lvt. I know that libvt was written for C68, but....
I´m going nuts trying to find some kind of equivalent to a conio-like library.
Anyone solved this ?
Re: LibVT
Probably stupid question, but did you include "ansicondef.h" in your source?
SM7I
Re: LibVT
Post by SM7I »
Yes, of course. Otherwise I’d get error instead...
Re: LibVT
xtc68 uses the exact same libraries as C68 - No problem.
Can you give the command line you used to build your program?
SM7I
Re: LibVT
Post by SM7I »
qcc -lvt test.c -o test
Re: LibVT
SM7I wrote:qcc -lvt test.c -o test
Put the "-lvt" to the end of the command line and you should be fine.
Linker command lines are sensitive to the order of options. "-lvt" at the beginning tells the linker "first look for any unknown symbols in libvt_a and resolve all, then compile and link test.c with the standard libraries". At the point "-lvt" is done, there are no unknown symbols (yet, because test.c is compiled later), thus nothing from libvt is actually pulled into your program.
SM7I
Re: LibVT
Post by SM7I »
Hi Tobias,
Yeah, thanks. That solved the issue :) If only all aspects of life was as simple as this....
Re: LibVT
I was going to port ncurses to C68, do you think this would be of any use?
Re: LibVT
Derek_Stewart wrote:Hi,
Of curse!
SM7I
Re: LibVT
Post by SM7I »
Yes please.....
