Has anyone got any spare Psion software packs (the common original Quill, Abacus, Archive and Easel for Microdrive)?
Thanks,
Spare Psion packs, please!
Re: Spare Psion packs, please!
I have loads of spare cases and cartridges (both v1 and v2 software, plus some for the US versions).
PM me with details of what you are actually looking for? For example, versions - do you need them to be on refelted cartidges and tested or happy to take non-refelted cartridges and replace the felt / reformat and put the software on yourself?
I'll pm you.
If anyone else has spare packs of Psion software, I'm still on the look out.
Thanks Jon, I think I probably have enough to be getting on with at the moment.
I'm in Germany too, and it tends to be expensive to post them, not that it was cheap before Brexit. They should certainly fall under the customs limit though.spkr wrote:I got a pack I can get rid of, but you seem to be filled
I'd pay £10 per pack of 4 in the original case.
Could probably give an address in the UK, not that I plan to be over for a while.
I'm in the Netherlands. I suppose I should write a post on the welcome part of the forumChr$ wrote:I'm in Germany too, and it tends to be expensive to post them, not that it was cheap before Brexit. They should certainly fall under the customs limit though.spkr wrote:I got a pack I can get rid of, but you seem to be filled
Ah, well postage will be reasonable thenspkr wrote:I'm in the Netherlands. I suppose I should write a post on the welcome part of the forumChr$ wrote:I'm in Germany too, and it tends to be expensive to post them, not that it was cheap before Brexit. They should certainly fall under the customs limit though.spkr wrote:I got a pack I can get rid of, but you seem to be filled
