VDrive help...
genetika
VDrive help...
Post by genetika »
Hi.
I’m using a QL with Minerva, SGC, SuperHermes And VDrive without Vmap.
I ported psion software on vDrive, modified boot, but it doesn’t start ...
i ported the modified version off psion chess, but it doesn’t start...
All the above files start regularly from FLP1.
Is it an hardware problem ( superhermes conflict )?
Any suggestion is really appreciated...
Max
retro_collector
Brittle Membrane
Re: VDrive help...
Post by retro_collector »
Hi Max,
I was able to duplicate your problem. I have tetrodes ROM switcher and I switched in JS ROM and Minerva and Archive would start to load and stop.
I then turned off Minerva and have just JS ROM and toolkit II and the PSION apps boot Vdrive
Bill
Re: VDrive help...
Very odd - not sure why Minerva would affect this (although from memory it has re-written microdrive access routines).
One thing you possibly have overlooked is whether the help files will load - you would have to edit the executable files directly to change flp1_ (or mdv1_) to mdv3_ for the help files...
retro_collector
Brittle Membrane
Re: VDrive help...
Help files will load only if you have VMAP, once the VDrive is mapped as MDV1_ with VMAP 3, and the Vdrive now being MDV1_ then the help files will load.
With the boot file modified for MDV3_ its not enough, the app looks to MDV1_ for the help files.
Bill
genetika
Re: VDrive help...
Post by genetika »
retro_collector wrote:Hi Max,
Bill
Thanks!!
I have the Minerva ROM inside QL. . .
Maybe the solution is to upgrade to TETROIDS ROM Switcher , or a new FLASH update on VDRIVE.
Thank you for being able to reproduce the problem. :-)
Max
genetika
Re: VDrive help...
Post by genetika »
Bill
Hi Bill.
Do you think that VMAP Could solve this issue?
Or is it a ROM problem ?
Thanks !
Massimino
retro_collector
Brittle Membrane
Re: VDrive help...
Hi Max,
It appears to be a ROM problem. I am using Tetroid's ROM swicther. When I switch in Minerva Psion apps don't work. Use just JS ROMS it works. You could also use VMAP as the PSION apps look for MDV1_ and MDV2_.
I am using ARCHIVE and it boots from MDV1 and writes data to MDV2 automatically.
Bill
