QL Float format to C68 float format - sort of...
Evening All,
I'm writing a utility - it's a long term project of mine - in C68. For testing I'm using both xtcc on Linux, and compiling the code with gcc as well. I'm needing some code to convert a QL 6 byte floating point to a "normal" floating point both in C68 (native to the QL) and also for a float variable under gcc - purely for testing.
I'm assuming that floats under C68 are normal QL floats and will not need converting - I seem to remember this, but I might be wrong, but the "standard" float on Linux under gcc is way different. Can anyone point me at/supply a chunk of code to do the conversion please?
Much obliged. And, one day, If I ever finish this, you'll all be the first to know! ;)
Re: QL Float format to C68 float format - sort of...
NormanDunbar wrote:Evening All,
Norman,
Nope. C68 uses its own (or, rather IEEE) floating point format, different from and more precise than the QL's native format (it uses 8 bytes instead of six). C68 still can handle 6-byte QL floats, these are of type "QLFLOAT_t". That is, a Linux gcc "double" has the very same format as a C68 one.
Conversion between both formats is simple on C68:
QLFLOAT_t * d_to_qlfp( QLFLOAT_t * qlf, double val)
takes a double and converts it to a QLFLOAT_t and
double qlfp_to_d (QLFLOAT_t * qlfp)
goes the other way round.
For gcc, it's probably a bit more complicated - I'd look into the C68 library sources and port the above two routines.
Much obliged Tobias, thanks. I could take the lazy way out and just test on QPC, but what would be the fun in that!
I'll see what I can find in the source.
