My First Sinclair QL
rgh.key
Post by rgh.key »
Managed to pick a Sinclair QL up for £115 from eBay. It had its original charger, joystick with flying lead to connect into the proprietary 6 pin BT socket, 9 games and video cable. I didn’t think that was a bad deal at all :D
Now I have a shopping list of things I need:
1.) Scart or Composite Video Cable
2.) Original Utilities Wafers (Abacus etc...)
3.) Floppy Disk Interface Unit (Maybe next pay day!)
4.) Some blank wafers!
If anyone can help with anything please let me know, would be extremely grateful ☺️
dex
Re: My First Sinclair QL
Post by dex »
https://www.ebay.co.uk/itm/Sinclair-QL- ... 0814300633
Choose one: https://www.sellmyretro.com/search?keyw ... &listSort=
georgeo
Post by georgeo »
I have a Tetroid disk interface with Compact Flash, and find it to be an excellent addition. Microdrive wafers are getting fragile with age. Best to put everything on floppy and use the wafers sparingly.
Yes, the microdrives are just a curiosity now :) Has the keyboard membrane been changed? Or does it work ok?
Timbucus
Post by Timbucus »
I would also advise extreme care before you use any of the Cartridges in your QL - the felt pad usually fails, gets distributed in the cartridge and on the head. This causes a jam and a need to clean up - often the cartridge cannot be recovered or the tape cleaned well enough. It can also move to the next one you try so you end up ruining a few.
Unless they have been re-felted I would suggest not trying them - if you do ensure the felt is firmly on the copper carrier and does not disintegrate to the touch. Just hold the cartridge sideways and press gently with a plastic spatula end of a pen and you will see the effect.
SM7I
Post by SM7I »
I do alot of refelting. So far this year I’ve done 200. I use 8 track tape felt cit down to suitable size.
polka
Post by polka »
I am surprised by this Ebay offer, because I did my own SCART cable for my QL, and with the sole QL plug, it worked only with a special video monitor. For connecting to normal TV sets you have to send 5V from outside the QL plug to 2 other pins on the SCART. I did it by picking this tension from the power line inside the QL itself.
See viewtopic.php?f=2&t=2570&p=24975#p24975
POLKa
May the FORTH be with you !
POLKa
Hi POLKa
That lead from Retro Computer Shack works because it also connects the Composite PAL signal from the QL (pin-1) to the SCART Blanking input (pin-16) - which doubles-up to select between CompVideo (0-0.4V) and RGB (1V to 3V) on most TVs.
The Comp-PAL signal from the QL, whilst fluctuating, is on average sufficient to trigger RGB mode and thus saves providing a dedicated 1-3V signal level to SCART pin-16. Pin-3 from the QL (Comp-Mono) should also work.
Its a neat solution and has been effective for me across several LCD TVs at home.
retro_collector
Brittle Membrane
Post by retro_collector »
Congrats!
I also just picked up a like new QL. Owner said it was used once and put back in the box and comes complete. From the pics it looks like it was never used!
Only 120 quid :). Its costing almost as much to ship!
Got me an RGB to SCART cable, and SCART to VGA SIMPLE VIDEO SCALAR from JS Technologies with the QL firmware so the 3 characters is the over scan area will be displayed.
Any a VdriveQL, Super gold card, rom switcher, a power regulator, new keyboard membrane just in case and games, apps and all kinds of goodies
Cant wait to play
You will be all set with that lot :)
