keyboard microdrive led socket replacement?
Traindriver69
Post by Traindriver69 »
Hi all
I have just fixed a ql which had a blown ula but the only other problem is that someone before has broken the socket that the wires go into to power the power and microdrive leds does anyone know if this part is available anywhere.
many thanks
Szk
Re: keyboard microdrive led socket replacement?
Post by Szk »
This socket? An exact replacement for that will be very hard to find... :?
But you can replace that with a much better solution, look for a 6-pin kit of PCB pin header, pins and connector, from Molex KK or Dupont, like this: ;)
