SMSQ on Q-emulator for OS X
thorsinclair
Post by thorsinclair »
Hi all,
the topic says it all :-) How do I get SMSQ running on Q-emulator for OS X? Any ideas?
T
Sparrowhawk
Re: SMSQ on Q-emulator for OS X
Post by Sparrowhawk »
Best thing is to ask the author, Daniele Terdina, directly. He's usually very responsive and helpful.
http://terdina.net/ql/MacQL.html
And of course, once you have an answer, please post it here! ;)
a.k.a. Jean-Yves
thorsinclair
OK done ;)
As soon as I get a reply I will post it here.
thorsinclair
I've got (very fast) an answer from Daniele - thank you Daniele!. Q-emulator for OS X can run SMSQ/E. The version needed is the one for Gold Card / Super Gold Card, including the GD2 colour drivers if possible. Than it just needs to be loaded as on any other system (LRESPR). Sounds good to me!
Now I just need to get hold of this version of SMSQ/E. May sombody can provide help here, thanks.
Best,
T
Mr_Navigator
QL Fanatic
Post by Mr_Navigator »
I suspect you would get that on disk when purchasing a gold card (from new), i have no idea if this is available PD. :(
Mr_Navigator wrote:I suspect you would get that on disk when purchasing a gold card (from new), i have no idea if this is available PD. :(
SMSQ/e has always been sold separately on disk. The licence allows for the source code to be distributed freely (if you want a go at compiling it yourself), but the binary versions are only available new through authorised distributors.
I may have a second hand copy of the Gold Card version for sale if someone needs one.
I need one. :)
