Expand QXL.WIN
mhanias
Brittle Membrane
Expand QXL.WIN
Post by mhanias »
Is it possible to expand an existence QXL.WIN file i.e from 100MB to 200MB?
Re: Expand QXL.WIN
http://theqlforum.com/viewtopic.php?f=19 ... win#p15582 might help.
I think you need to create a new file and copy over the data. The size of the file determines the group size, so changing from 100 to 200 mb would change the group size from 4 to 7 and truly mess things up!
Group size 4 gives files up to 128 mb, and 7 gives up to 224 mb. The group size is the number of 512 byte sectors that each entry in the map covers, and, defines the smallest amount of space used on disc by a file.
You can read about the format of a qxl.win file at http://qdosmsq.dunbar-it.co.uk/doku.php ... sq:fs:qlwa and the group size and maximum qxl.win sizes at http://qdosmsq.dunbar-it.co.uk/doku.php ... roup_sizes.
HTH
Re: Expand QXL.WIN
On Dilwyn's site you may find a "script" called QLWARZ to do exactly that. Its packaged so as to run as a single operation: stretch, copy and rename, all in one. As it stands, however, it may not be suitable for all platforms. You may need to make some adjustments to things like WIN_DRIVE or its parameters to suit your system.
I think "messing things up" is too strong, Norm. The trick is to choose an optimal size for the amount and sort of data you intend to store. The information in QLWARTZ provides a brief overview. Norman's wiki article gives greater detail on this.
You can read about the format of a qxl.win file at http://qdosmsq.dunbar-it.co.uk/doku.php ... sq:fs:qlwa and the group size and maximum qxl.win sizes at http://qdosmsq.dunbar-it.co.uk/doku.php ... roup_sizes. <>
Re: Expand QXL.WIN
Hi Per,
When I said that it would mess things up, I meant if the file was extended to such an extent that the group size was changed but original data still remained. I thought I'd been clear, but reading back, it's obvious that I wasn't! My bad - as the youth of today might say. ;)
