Hi and some help please with display issue
Introduce yourself here!
Fred1halstead
Post by Fred1halstead »
Hi there
I've had a ql for about four years and fixed the keyboard. It's been in storage and now the screen is not displaying properly. It is jumping and not staying steady. It's a scart RGB lead, going into a 1080 flat screen TV.
Is it a ql fault or a dodgy lead?
Any thoughts would be very gratefully accepted thank you!
It all worked fine about four years ago!
Cristian
Re: Hi and some help please with display issue
Post by Cristian »
Fred1halstead wrote:It all worked fine about four years ago!
Did you connect to the very same TV of 4 years ago? To the same SCART slot?
Check carefully the pins of both cable and QL: can you see dirt or rust? Try to clean with proper spray cleaner.
Does something happens to video output if you gently move the cable?
Could you provide a video of the screen?
