RE: Q-Menu 8.02
simon629
RE: Q-Menu 8.02
Post by simon629 »
Hi how do you upgrade Q-Menu 8.02 on QLE/QDT can you please help OK thanks Simon Foster
BSJR
Re: RE: Q-Menu 8.02
Post by BSJR »
simon629 wrote:Hi how do you upgrade Q-Menu 8.02 on QLE/QDT can you please help OK thanks Simon Foster
If you want the full package to use it in your own written programs, you need to contact JMS, it's still commercial.
If you only want to upgrade Menu_rext you may already have it if you recently upgraded a PE program like QSpread, i believe it's also on the latest QLE you use (check win1_sys_).
There is a catch however, mentioned earlier on this forum: QDT doesn't work well with it so until that is solved you'd better stick with v7.66, also on the QLE.win.
Bob
simon629
Re: RE: Q-Menu 8.02
Post by simon629 »
Thank you Bob I have two ZIP Files QMenuZIP and MENUZIP I copy the files from QMENUZIP to sys Folder then wwhat do I do OK thanks Bob Simon Foster
