uQLx: unzipping Qpac2 gives checkdir error: cannot create qpac2
ql_freak
Post by ql_freak »
When I try to unzip Qpac2 on a QXL.WIN device (which contains subdirectories) I get the above error. I can list the subdirectories and set the DATA_USE to it, but it seems impossible to create subdirectories.
It is also not possible to RENAME files:
RENAME'WIN1_up_tmp_hot_rext_english','WIN1_up_tmp_hot_rext'
gives "bad parameter".
