New option for QIMI users?
I have just seen a new adaptor listed on sellmyretro which allows you to use a USB mouse with a 9 pin connector. As it has been tested and works with the Amiga - I wondered whether it might work with the QIMI to allow a modern mouse to be used (instead of the hard to find bus mice)...
A bit expensive, but would certainly be of interest.
http://www.sellmyretro.com/offer/detail ... rev2-22792
I have emailed the seller as the main issue is whether the device could handle both mouse buttons being pressed at the same time....
Re: New option for QIMI users?
RWAP wrote:I have just seen a new adaptor listed on sellmyretro which allows you to use a USB mouse with a 9 pin connector. As it has been tested and works with the Amiga - I wondered whether it might work with the QIMI to allow a modern mouse to be used (instead of the hard to find bus mice)...
Is this on the same lines as Marcel's blog article here ?
https://www.kilgus.net/2017/01/30/of-mi ... stly-mice/
dilwyn wrote:Is this on the same lines as Marcel's blog article here ?
I don't think so, because it seems to actually support USB. The one in Marcels's blog is only for PS/2, and requires "PS/2 USB combo" devices.
HI,
The mouse adapter on Sellmyretro, looks expensive, the adapters have been on eBay for a while now.
This could be used:
http://www.ebay.co.uk/itm/The-New-MKIV- ... SwEK9T8exS
But will have to altered little to work with QIMI, the Atari option will work, but the middle button or press 2 buttons at once to emulate the middle button will need a hardware or software change.
It might be easier to reverse engineer the ICE mouse to work with QIMI, I did something like this in 1990s, I can not remeber the details, I have a scrap of paper with the QIMI-ICE-ATARI-AMIGA comparisons.
