RE: Folder Icons on Black Phoenix
Hi can any one help me When I try to change a Folder Icon I get a egg Timer with a Red Mark with a White Line I have got you a screen Shot OK Thanks Simon Foster
Re: RE: Folder Icons on Black Phoenix
QDT also struggles if you want to change an icon on an application.
I think this is just because some features of QDT were never finished
I wonder if you updated the Menu_rext in your Black Phoenix.simon629 wrote:Hi can any one help me When I try to change a Folder Icon I get a egg Timer with a Red Mark with a White Line I have got you a screen Shot OK Thanks Simon Foster
The one used in BP is a quite old v7.02 (?1996, mode 4 only), the current v8.0x gives this problem in QDT.
A List_Select menu should open but it hangs instead. Older versions up to v7.66 (2003, GD2 capable) will work.
SuQcess will not work with Menu_rext older than v7.50.
The QDT should be updated.
Bob
