EASYEXT toolkit AND documentation now online
ql_freak
Post by ql_freak »
In the Software section you will find now the excellent EASYEXT Toolkit, which allows to temporarily load extensions (e. g. SuperBASIC toolkits) and remove them savely (with e. g. the Rjob menu from QPAC2). This is usefull for anyone, not just for programmers. E. g. if you want to run a program which needs a SuperBASIC toolkit, which you normally don't have loaded. You can load it with XJ and after you have exited the program you can remove it with RXJ.
See: http://www.theqlforum.com/viewtopic.php? ... 711#p15046
Here the README.txt:
EASYEXT Toolkit from EASYPTR II from Albin Hessler
This Toolkit allows to install QDOS extensions to load
into the common heap, the resident procedure area AND
the Transient Program AREA (with XJ) AND REMOVE these
extensions (SuperBASIC extensions, drivers, tasks, ...)
savely(!).
It includes an excerpt from the original EASYPTR II
manual for "easyext_res" translated from (original)
German to English.
Copyright (c), 2016 for translation:
Peter Sulzer, Fürth, Germany
Released under the same license as the now freeware
EASYPTR (now maintained by Marcel Kilgus) except, that
the copyright notice (especially in "easyext.pdf") must
not be removed.
