QL-Expansion slot, where to get the edge connector?
Does anyone know, where the connectors of the QL expansion bus are available, edge (male) and socket (female) connectors (both with and without 90 degrees angle) so you can build a backplane with more than one slot?
Re: QL-Expansion slot, where to get the edge connector?
For a backplane, he may need them with straight pins (ok, haven't look further there...Paul wrote:Female:
https://www.reichelt.de/Messer-Federl-D ... OFFSET=500
Male:
HTH
- ROM Dongle
Hi
I bought then in RS. I put the result of searching them in rs germany
http://de.rs-online.com/web/c/steckverb ... 1&aaaExp=Y
The code for female a+b 64 and 90º I use is 542-4675. I'm a bit surprise the price in germany is much cheaper that in spain :-O
Bye
José Leandro
Bye
José Leandro
Why do you think it's called a DIN connector?
- ROM Dongle
Hi
Bye
José Leandro
And also because RS slots put "made in germany" XD XD XDDave wrote:Why do you think it's called a DIN connector?
Bye
José Leandro
- XorA
- Site Admin
Its short for DINnae use, pain in the ass!Dave wrote:Why do you think it's called a DIN connector?
They're great connectors, but they're not very dense.
The density is ok regarded to the Time when they were developed.
I think it's a pity that those quality connectors were designed for only 400 uses!
When you do some testing you are plugging those hundreds of times in one evening!
