I've just realised the EXTRAS command doesn't work as expected in a daughter SBASIC job in SMSQ/E (QPC2). It lists the keywords of the commands I've typed in.
For example: I open a new interpreter with the SBASIC command. I type "DIR ram1_:PRINT 0", then "BEEP 1,0" and finally "EXTRAS"... The keywords in the list are DIR, PRINT, BEEP and EXTRAS!
I think it didn't happen with SMSQ and my QXL years ago, but I'm not sure. Anyway it makes no sense. It seems a bug. The QPC manual says nothing special about EXTRAS.
Bug in EXTRAS in SMSQ/E?
- programandala.net
- Chuggy Microdrive
Re: Bug in EXTRAS in SMSQ/E?
This the default behaviour - I quote the SBASIC / SuperBASIC Reference Manual on this:
Within an SBASIC ( on SMS ) , EXTRAS only lists those keywords used in that SBASIC to date - this is because the whole name table is not copied when an SBASIC is started up, allowing different SBASICs to use the same name for different things.
- programandala.net
- Chuggy Microdrive
Thank you! There's no mention about that in the manuals bundled with QPC2 (I searched all the PDFs for EXTRAS before posting), and I don't have the Reference Manual.RWAP wrote:This the default behaviour - I quote the SBASIC / SuperBASIC Reference Manual on this:
But I don't understand two issues (because of my ignorance of the inner working of the interpreter):
1) I guess "The whole name table is not copied when an SBASIC is started up, allowing different SBASICs to use the same name for different things" means I could load an extension within a daughter SBASIC, with the same name but different behaviour than other extension already loaded in other running SBASIC, even the main one. Is it right? And an extension loaded into a daughter SBASIC is not avalaible in other SBASIC jobs. So every SBASIC keeps its own name table. But the standard commands are avalaible anyway in all SBASIC jobs, and the extensions loaded into the main SBASIC job are avalaible in the daughter SBASICs too. What's the problem about listing the avalaible keywords in the daughter SBASICs?
2) What's the point of listing the used keywords? Is it an irrelevant side effect or does it have any goal?
I find out this "non-bug" while checking a simple procedure I wrote to print EXTRAS into a ram file and check if some keywords are avalaible (In such cases I use the EXISTS extension, by Phil Borman, but In a special case I needed to check if EXISTS actually exists!). Everything worked fine in the main SBASIC job, but not in the daughters...
Marcos,
this won't help much in your specific case, but for the sake of completeness:
Minerva copies the complete set of EXTRAS into daughter basic jobs. (I.e. EXTRAS shows identical output in job 0 and daughter basics.)
I'm not sure what happens should you try to override one specific S*Basic extension by another one in a daughter basic. The manual implies it should work.
And, in an attempt to find some reasoning for the (admittedly weird) behaviour:
I can quite well understand that there is is a (needs to be a...) job specific name table. A merge of all S*Basic Name entries would not only give a problem when overloading extensions in daughter basics, but also when a daughter basic ends (how should the OS know what names can be purged from the - then joint - name table?). So the algorithm seems to be: If you encounter a name, look into the job private name table. If you can't find it there, try to copy if from job 0.
EXTRAS should probably do the same - First list names from the daughter basic's NT, then do the same from job 0. And I guess it's just a side effect (or an omission in neglect of S*Basic jobs from the requirements.)
Cheers
Cheers
Yes, toFro's interpretation is correct.
EXTRAS will first of all list definitions within the local SBASIC name table, and then looks to the main one - this has the effect that only used extensions are visible UNLESS you link a new toolkit into an SBASIC daughter job (ie. they get patched into the local SBASIC name table) - EXTRAS when used from within that SBASIC should then list all of those extensions as available.
Outside of that SBASIC, EXTRAS will not find the extensions.
This can be useful for coding new versions of existing SuperBASIC keywords for future development of SMSQ/e
As for the reference manual - it can be purchased on sellmyretro.com -
http://www.sellmyretro.com/offer/detail ... on_CD-1397
- programandala.net
- Chuggy Microdrive
I tried VOCAB, a much improved version of EXTRAS, part of the DIY Tookit written by Simon N. Goodwin, and the same "problem" happens.
