Okay, the distilled issue is this:
I have downloaded the full QUANTA library catalogue, and have been trying to access LG01, which provides a guide to the whole resource. I am now trying to use Qemulator for the Mac (full version) to look through the library;
Essentially, I am planning to place a copy of the resource on my new QL-SD card so I can access the whole lot from my QL, and actually use it, rather than the tinkering I have done so far. However, I would like to take a look through it first;
After some initial problems outlined in the other thread, I re-downloaded the QUANTA library guide from the website, and have been able to load the boot file.
I have modified line 1080 to suit accessing the virtual mdv1_ device in Qemulator
When I RUN the program, I get an error 'at line 1100;1 not found. Line 1100 is LBYTES device$ & 'data_bin', addr. I am assuming here that the program is unable to call the virtual microdrive.
I have gone no further, but I assume that once I have run this programme successfully once, I have to use REM commands for lines 1095, 1100 and 1105 to disable them, and then the program should work?
There is clearly something very fundamental that I am missing here, but despite a couple of hours last night and another hour this evening, I am making little progress.... HELP!
