QPC1 and DosBox
QPC1 and DosBox
QPC1 and DosBox
Since I've migrated to Linux for my desktop system, my selection of QL emulators is not very big. The best and my favorite is SMSQmulator. It is fairly powerful, but it has limitations in that it is not a QL emulator but a platform for SMSQ/E. This means that very early programs that only run on a QL, will not run on it.
QPC1 has recently been released and that looks to be another option for me. I've heard that some programs that will not run on SMSQmulator, might run better under QPC1. QPC1 is only for DOS, which leaves a bit of a quandary for a Linux user. Luckily, there is DosBox, which creates a DOS environment, perfect for running QPC1. DosBox is primarily designed for running old DOS games from the early to mid 1990's, but I've used it to run the DOS version of the PSION programs with no issues. DosBox runs on a number of platforms, including Windows, Linux and Mac. It does a good job of providing a DOS environment for running a number of DOS utilities. DosBox is freely available from http://www.dosbox.com. Download the specific version for your operating system and install it using the directions from the DosBox website.
I will assume that you know where to find QPC1 and be able download it.
Configuring DosBox for QPC1
To get QPC1 to run on DosBox, three settings have to change. Open the DosBox config (dosbox.conf) file using a text editor. See the DosBox documentation to find out where your version is located. For Linux, the config file is in the .dosbox directory. Find the EMX, XMS and UMB section of the file and set the following:
xms=false
ems=false
umb=false
Setting up DosBox
DosBox can read the underlying file system of the operation system, and can run DOS executables from that file system. It is recommended to create a DOS directory and then place all DOS files in sub directories under this directory. This will keep all of your DOS files in one location. One thing to remember, once DosBox is started, do not edit the DOS directory with the file system tools. DosBox will not notice any changes until it is restarted again.
When DosBox is started, it will give a Z: drive as the local directory. You can mount the DOS directory from the local file system like this:
mount c c:\dos - Windows
mount c /home/user/dos - Linux
c: - Move to C:\
Instead of doing this every time you fire up DosBox, you can add it to the autoexec part of the DosBox config file. Look for [autoexec] in the config file and add the above statements just after it. These commands will be run each time DosBox is started.
Starting QPC1
Once DosBox is started, just CD to the directory where QPC1 is located. For the first time running QPC1, you will need to run the program "config" and set things like the keyboard and what QXL.WIN files to use. Once that is done, execute 'qpce' for English or 'qpcd' for German.
Hints with DosBox
Mouse
By default the mouse is trapped by DosBox, not allowing it to leave the DosBox window. The mouse can be untrapped by hitting CTRL-F10. To turn this feature off, set "autolock=false" in the DosBox config file.
Larger Resolution
DosBox allows for higher resolution than VGA. QPC1 also allows for higher resolution. DosBox and QPC1 has been successfully tested with a resolution of 1024x512. See the DosBox and QPC1 documentation on how to change the resolution on each.
Full Screen
DosBox can be set to full screen by using hitting ALT-ENTER. Hitting this again, will turn off full screen. If using QPC1 in 512x256 mode, going full screen will enlarge all of the text making it easier to see and provide for a more "normal" QL experience.
Exit from QPC1
For those that don't remember, exiting from QPC1 back to DosBox can be done by the QPC_EXIT command. DosBox can be exited by clicking on the (X) close box while QPC1 is running, but quitting from QPC1 is probably more graceful. Once back at the DOS prompt, 'exit' will exit DosBox.
Floppy Access
DosBox does not support low level access to floppy disks, even if they are attached, so don't expect to use floppy drives, even though QPC1 can directly access floppies.
Printer Access
DosBox does not support printers or the printer (LPT) port, which means that even if you used software that captures data to the LPT port and sends it to a file, it will still fail. There is a special build, call Hal9000, of DoxBos that is reported to support the printer port.
DOS Access
QPC1 does not have the DOS1_ device that QPC2 has. There is no way for QPC1 to access files stored under the underlying file system. This also means that there is no built-in way to transfer files from DOS to a QXL.win file and back. Jonathan Hudson's qxltools is the best option. There is a front-end called wqxt2, but it is only pre-compiled binary for Windows.
xms=false
ems=false
umb=false
Setting up DosBox
c: - Move to C:\
Starting QPC1
Hints with DosBox
Mouse
Larger Resolution
Full Screen
Exit from QPC1
Floppy Access
Printer Access
DOS Access
- Sparrowhawk
Re: QPC1 and DosBox
Thanks for the detailed instructions. Very useful indeed!
Just some extra info: for Mac OS X users, the location of the config file is:
(Change the version number to the one matching your version of DOSBox)
~/Library/Preferences/DOSBox\ 0.74\ Preferences
a.k.a. Jean-Yves
Re: QPC1 and DosBox
Thanks Tim, great post, very helpful.
I had unsuccessfully tried DOSEMU but QPC1 refused to run in protected mode. Works OK in DOSBOX after setting up as you detailed. The only problem is, like SMSQmulator, it causes the CPU fan to run all the time...
David
Re: QPC1 and DosBox
I have been configuring Dosbox for a games player to play a Dos game in Windows 7. All seem to work great.
I noticed Dosbox is available on the Android platform in the Google Playstore called Freebox.
I installedFreebox on a Samsung Galaxy Tab3 10.1 and was able to run QPC1v1.52, see photo of QPC1 running Emacs on the tablet.
Not bad for a quick 10 minute attempt.
Re: QPC1 and DosBox
Is it the same app as aFreeBox?
(there are so many apps with 'Freebox' in the name it was hard to find it)
Re: QPC1 and DosBox
Looks good, but seems to be hard to use without a real mouse and/or a proper keyboard.Derek_Stewart wrote:Hi,
Re: QPC1 and DosBox
That is interesting to read. When I first bought QPC2 several years ago, I had an nVidia graphics card with two fan speeds in my PC. When starting QPC2, the fan speed always set itself to the higher speed. Nevertheless if the PC was just switched on or running for several hours.Silvester wrote:Thanks Tim, great post, very helpful.
I have never found out why it does this, so gave up and bought a graphics card without a fan. Pehaps MK has an answer but I have never asked
Re: QPC1 and DosBox
Do not know, I just did a search on the Google Play Store for DosBox and Freebox looked a reasonable option.dilwyn wrote:Is it the same app as aFreeBox?
Re: QPC1 and DosBox
Well there is an on screen keyboard, I installed the Hacker Keyboard, which allowed use of more keys. But I suppose a Bluetooth keyboard and mouse could be used. But I doubt I will continue with the this.Ralf R. wrote:Looks good, but seems to be hard to use without a real mouse and/or a proper keyboard.Derek_Stewart wrote:Hi,
It is a bit like going back to use microdrives and pre-Minerva operating systems...
Re: QPC1 and DosBox
Probably the answer is in the QPC2 Power Management in the Emulation Options, QPC2 may draw more power due the Graphics I/O.Ralf R. wrote:That is interesting to read. When I first bought QPC2 several years ago, I had an nVidia graphics card with two fan speeds in my PC. When starting QPC2, the fan speed always set itself to the higher speed. Nevertheless if the PC was just switched on or running for several hours.Silvester wrote:Thanks Tim, great post, very helpful.
I have never found out why it does this, so gave up and bought a graphics card without a fan. Pehaps MK has an answer but I have never asked.
