Too fat to plug-in...
chriskgnr
Brittle Membrane
Post by chriskgnr »
Hello to everyone! :)
Recently i purchased 2X 6way, 630A type plugs and 2X 6way, 631A plugs to use them with homemade(that i wanted to make) SER and CTRL ports cables. But they don't plug in. They are.. fat! :o And i checked again and again the photos before i put my order... :?
Re: Too fat to plug-in...
There was a thread on this - http://www.theqlforum.com/viewtopic.php?f=2&t=530
Unfortunately, no-one seems to know the exact part number for the original plugs used for the QL / Spectrum
You will need to file them down to fit - or I do have some QL serial port adaptors (to 25 pin) here if you would prefer one of those.
Mr_Navigator
QL Fanatic
Post by Mr_Navigator »
Some images of the Left and Right plugs with a white BT for comparision.
You should be able to see the difference between the BT and QL versions and what to remove from the BT one on a couple of the pictures.
https://plus.google.com/photos/10876152 ... 4001733249
chriskgnr
Brittle Membrane
Post by chriskgnr »
hmm, yes. I'll try to file them down. Thank you! :D
