QL Demo ROMs Copyright?
I have the QL Demo ROM board for retailers, which can now be run in Q-emuLator (from 3.5.2)
But I don't know what the copyright situation would be to make the ROM(s) available, anyone know please?
The first ROM header says
QL Demonstration 1.00
Sinclair Research Ltd.
bi Si <-- no idea what this means, maybe just a co-incidence that it's text or a spelling mistake?
Hardware by Jon
Eproms by Eric
Re: QL Demo ROMs Copyright?
I don't think that's a problem. Even all the QL ROMs are on Dilwyn's website and that doesn't cause any problems.
Without QL, this extension would be completely pointless.
jobdone
Post by jobdone »
Is the demo the same one that is in the Qubbesoft PD library (except not in Rom format). disk7? if it is this may answer your question.
jobdone wrote: Tue Feb 25, 2025 8:31 pm Is the demo the same one that is in the Qubbesoft PD library (except not in Rom format). disk7? if it is this may answer your question.
Thanks that's the one!
As far as I know, there are two versions, one in SuperBASIC and one in machine code, which look the same.
RalfR wrote: Tue Feb 25, 2025 9:18 pm As far as I know, there are two versions, one in SuperBASIC and one in machine code, which look the same.
So the m/c version could still be in copyright
I don't think anyone would care about copyright anymore.
ql_freak
Post by ql_freak »
RalfR wrote: Wed Feb 26, 2025 7:55 am I don't think anyone would care about copyright anymore.
<GRIN>
I had a llook at the demo program, I can not see the ROMs, or how this works, and how to pug the applications into ROM.
