Hi, for testing it would be really useful if I could have a simple patch to remove MDV IO from the JS rom. So it never tries to read the mdv drives.
Something like a simple RTS injected in the right place. Does anyone know of a simple way to do this?
Disable MDV in JS rom
- Trump Card
Re: Disable MDV in JS rom
Would it be sufficient to just rename MDV device name to something obscure ? (name in linkage at JS ROM offset 4695, $1257)
- XorA
- Site Admin
BINGO! You win one free bit from the MD of your choiceones' complement wrote: Mon May 15, 2023 4:26 pm Would it be sufficient to just rename MDV device name to something obscure ? (name in linkage at JS ROM offset 4695, $1257)
I changed that to XXX and now I can test other parts of the emulator!
