Metacomco Pascal Manual
I am trying to OCR a very badly scanned copy of the Metacomco Pascal Manual, but the scanned version is not very good.
I would like to buy or loan a Pscal Manual to update my scanning project
Re: Metacomco Pascal Manual
Hi Derek,
I have a copy that I can lend you (send you via post) or make a scan. My predecessor punched holes in it to make it fit for a binder, but the text is largely unaffected.
Would be glad to help. Cheers
Hi,AndyZX wrote:Hi Derek,
Your manual sounds what I would like to scan, can you send it without the binder?
I have sent you a PM with my address details.
Sure. Just to give you an idea how it looks likeDerek_Stewart wrote:Hi,AndyZX wrote:Hi Derek,
Hi Andy
Your manual looks great, my scanner should scan it easily
The PDF file I was using from the Spanish web site is so badly scanned, it is unteadable.
check it here:
https://sinclairql.speccy.org/archivo/d ... acomco.pdf
check it here:
Here is the completed scanned and OCRed Metacomco Pascal Manual.
Thank to AndyZX for supplying the original manual for scanning.
The manual is in PDF and LibreOffice ODT formats.
If there are any errors in the manuals let me know and I will try to correct them.
- Sparrowhawk
Thanks Derek, I agree with Sparrowhawk - the scan is of great quality! I think it should be put on Dilwyn's Sinclair QL Homepage (now part of this Forum anyhow) to make it more visible to the QL community.
I should of put this in the Software section..
The manual was scanned to PNG files, cleaned up the images, black borders and other rubbish. Convert to PDF, and OCR with OCRMYPDF, produces a ASCII text file.
The text file loaded into LibreOffice Writer, which was used to proof read the scanned images compared to the text.
Once verified, I exported the file to PDF.
The LibreOffice file is also available for future corrections.
Hi Derek,
great work! Thank you.
In 1987 I bought (not copied!) Metacomco Lattice C. Made me happy then. Besides learning C I had fun with the screen editor ED, which is also part of the Pascal package (and many other programming packages from Metacomco).
The PDF manual you produced is nice and nicely readable.
Well done!!!
Well done!!!
