hi! i don't know if anyone here knows msxpen:
https://msxpen.com/codes/-Mv8RfvKZbfj6ct_6qmb
it allows us to code and share a msx-basic code, an run it on webmsx (html5+js msx emulator)
so, how possible would be having something like this related to sinclair ql?
it's missing something like msxpen+webmsx
- nitrofurano
- Chuggy Microdrive
Re: it's missing something like msxpen+webmsx
You might want to check out this
- nitrofurano
- Chuggy Microdrive
yes, that is indeed great - but i think you didn't see what i shared: it wasn't merely a html5+js emulator link with a mounted imagedisk file somewhere, but instead a weblink of a basic-language code (just like sharing a code at pastebin) linked to a running html5+js emulator
for example, take a look at this: https://msxpen.com/codes/-Mv8fAiK-1lEkfYIyfdW
I checked out your web link, looks a MSX2 emulator.
To convert it to a QL you need to change the Javascript to interpret Superbasic and change the Javascript 6502 emulation to 68000 emulation.
Is this a hard job, probably...
