CSM 1.22
Giorgio Garabello
CSM 1.22
Post by Giorgio Garabello »
Hi everyone. I am trying to learn how to use the CSM 1.22 extension
I have launched the attached examples but I see nothing.
I am using QPC2 with SMSQE 3.36
Can anyone help me?
Giorgio
Re: CSM 1.22
What is "CSM"?
Re: CSM 1.22
I used use Pbox as BBS System, by Phil Borman,,which used CSM, or Client Server Manager by Jonathan Hudson.
I have not usedCSMin while so will have to review the system again.
swensont
Re: CSM 1.22
Post by swensont »
CSM is for interprocess communications (sort of like RPC's). A program is a server and can be controlled by a client program sending commands.
I did not see any attached examples. Were you referring to the examples that came with CSM?
Tim
Giorgio Garabello
Re: CSM 1.22
swensont wrote:CSM is for interprocess communications (sort of like RPC's). A program is a server and can be controlled by a client program sending commands.
Tim
In the zip file there are some _bas
They are also mentioned in the txt manual
http://www.zen35309.zen.co.uk/qdos/#heada
