QXLDump
QXLDump
Greetings one and all.
I'm playing with QXL.WIN files, again! As part of something I'm working on, I needed a simple way to examine the internals of a qxl.win file in an easy manner. To this end, QXLDump was born.
At the moment I have a download for 64 bit Linux only, hopefully, I'll get a Windows version uploaded at some point tomorrow. However, if you have been reading my "how to upgrade the online SuperBASIC manual" documents at http://readthedocs.io and as mentioned here then you'll be well aware of how you can get your hands on a free, up to date, standards compliant C and C++ compiler from Embarcadero. You'd be silly not to take advantage of their offerings.
Anyway, for now, if you need a Windows version, then download the source and compile it yourself.
You can see a sample of my current win3 drive - which is a full set of the Sqlite 3 sources from some time back, at http://qdosmsq.dunbar-it.co.uk/download ... /win3.html. The file was created with a random selection of options! There is also a verbose mode which hexdumps each and every block making up the directories, files etc - best avoided unless you are debugging a foible, or something similar!
The Read-me file is at http://qdosmsq.dunbar-it.co.uk/download ... EADME.html.
The Linux 64 bit download is at http://qdosmsq.dunbar-it.co.uk/download ... mp/QXLDump.
No additional libraries etc are required, everything is in plain vanilla C++ with the odd bit of the STL thrown in for good measure - thats the Standard Template Library.
As ever, source code is available at my GitHub location, and will be cloned into the SinclairQL repository as soon as I'm happy with it. I have a couple of minor changes to make, but nothing spectacular. The source is at https://github.com/NormanDunbar/QXLDump which you can freely clone if you already use git, or, download as a zip file from this location: https://github.com/NormanDunbar/QXLDump ... master.zip.
The utility allows you to dump out the following:
  • The header
    The map
    The root directory
    The free space list
    Any datafile
    Any directory
    Any single block
And most of the above can be accompanied by a hexdump - if you are brave.
Output is only to HTML at the moment and I have no plans to make it text only, at the moment - but if you have an itch, scratch it and feel free to add the required code to do exactly that.
Have fun!
Re: QXLDump
The windows version of QXLDUMP has been uploaded. It is 32 bit but runs fine on 64 bit systems. Just the exe file is required.
http://qdosmsq.dunbar-it.co.uk/download ... XLDump.exe is the link.
Have fun.
