Sprite test
Marq
Sprite test
Post by Marq »
Today's experiment: big sprites running at 50 Hz with full masking and background.
http://www.kameli.net/~marq/bigsprites
lbytes to 196608 and then call. Disable toolkits and other extras, as this one hits the hardware pretty directly. Tested on a vanilla QL with QL-SD/Minerva.
thorsinclair
Re: Sprite test
Post by thorsinclair »
Cool stuff!
Is this a self written or ported? Need to test it 8-)
Marq
Re: Sprite test
Post by Marq »
thorsinclair wrote:Cool stuff!
I just started writing it from scratch this morning :)
Re: Sprite test
Coo! 8-) when is the demo coming? :D
Marq
Re: Sprite test
Post by Marq »
vanpeebles wrote:Coo! 8-) when is the demo coming? :D
Something small possibly this year, I suppose. The biggest trouble now is sound, which seems to eat up too much time from the effects plus I haven't found any tools for composing for the weird sound API of the 8049.
thorsinclair
Re: Sprite test
Just for info: I tried it in Q-emulator this morning, choosing Minerva and 128 KB RAM and it has a flickering in the upper part of the screen.
Marq
Re: Sprite test
Post by Marq »
I think that the emulator doesn't deal with page flipping in the middle of the screen, but a real QL can do that. Another similar effect didn't work with it either.
Re: Sprite test
When I get chance I should try this - Minerva probably struggles due to the way it handles the second screen - might need to try it on a JS ROM on q-emulator, or Minerva in dual screen mode for example...
Marq
Re: Sprite test
Post by Marq »
RWAP wrote:When I get chance I should try this - Minerva probably struggles due to the way it handles the second screen - might need to try it on a JS ROM on q-emulator, or Minerva in dual screen mode for example...
It should work pretty much the same with the standard ROM – haven't tried yet, tho. It will still flicker on the emulator no matter how the pages are set up, since I change the graphics page during the refresh at about line 40. Above that the pixels are always from page 1.
edit: confirmed to run fine on a vanilla QL.
